Bunn coffee maker
A Bunn coffee maker is just like every other coffee machine. Before using the Bunn coffee maker, you will need to fill up the brewer that is found on top of the maker, with 2 pitchers of water. Place a coffee filter into the brew funnel and add in coffee grounds. Slide the funnel into the brewer, make sure there is an empty coffee pot under the brew funnel. Turn the lighted warmer switch to the "ON" position. Once your coffee is all brewed it is time to enjoy.
