🧡 Wanted Fan for a Royal #5
Jjwolfe62
Looking for a replacement Fan for a Royal #5.
Someone replaced original with a Squirrel cage style.
I don't feel it's enough air
Any direction would help
Finding a suitable replacement fan for a specific appliance like a Royal #5 can be challenging, especially if the original fan has been replaced with a different style. Here are some steps you can take to find a replacement fan:
  1. Identify the Fan Type: Since the original fan was replaced with a squirrel cage style, you need to determine the specific size and type of the squirrel cage fan. Measure the diameter and width of the existing squirrel cage fan to find a replacement that matches those dimensions.
  2. Check the Manufacturer: Look for the manufacturer's label or tag on the appliance (Royal #5) to identify the original fan model number or part number. You may be able to find replacement parts directly from the manufacturer or authorized dealers.
  3. Contact the Manufacturer: Reach out to the manufacturer of the Royal #5 appliance and inquire about a replacement fan for the specific model. They might be able to provide you with the correct part or direct you to an authorized service center.
  4. Appliance Repair Shops: Consult local appliance repair shops or HVAC (Heating, Ventilation, and Air Conditioning) service providers. They often carry a wide range of replacement parts, including fans, and may be able to help you find the right replacement.
  5. Online Retailers: Search online retailers and marketplaces for the specific fan size and type you need. Use the measurements you obtained from the existing fan to narrow down your search.
  6. Specialty Fan Suppliers: Look for specialty fan suppliers or HVAC parts distributors that offer a variety of fan types and sizes. They may have a broader selection and be able to provide guidance on choosing the right replacement fan.
  7. Consider Airflow Requirements: If you believe the current replacement fan is not providing enough air, consider checking its specifications (CFM - Cubic Feet per Minute) and compare it with the original fan's specifications. Look for a replacement fan with a similar or higher CFM rating to ensure adequate airflow.
  8. Seek Professional Assistance: If you are unsure about finding the right replacement fan or the installation process, consider seeking help from a professional HVAC technician or appliance repair expert.
Remember that for safety and optimal performance, it's essential to use the correct replacement part that matches the original specifications of the Royal #5 appliance. Using the wrong fan could result in reduced efficiency, improper operation, or damage to the appliance.
