Help Please: Jura Z7... 3-way outlet valve...leaking
tomsz7
I have Jura Z7 still in great shape.....there is a small 3way outlet valve ont he fluid system that is leaking..oddly..it looks like it is leaking from the sides and out the top....the part is $99.....probably costs $0.25 to make...I am just making sure there isn't a simple repair/maintenance item that will get it back working.
It doesn;t look cracked or damaged in any way.
Thanks to anyone that can help
if you remove the tubes are there any gaskets or seals on it ? if there are ,try replacing them first and see if it still does it
