improvised pouring equipment
bvanevery77
Top Poster Of Month
People might not realize that in my coffee bean reviews, I'm providing a pile of information on seriously cheapskate pourover methods. I should document some of it here, and try to solicit discussion. Pity to have a perfectly good pourover section chirping crickets, when pourover is all I do.
I forget exactly but I think I have 3+ years of pourover experience now, starting with very much poverty driven methods. If I could do it with ones or tens of dollars instead of hundreds, I tried it. I've even ground my coffee with a $25 mortar and pestle meant for crushing small pills, and frankly I don't recommend that one. The grind was never great and the effort got seriously old lol.
The most semi-successful improvisation so far has been pouring down the handle of a piece of silverware. This can spare you needing a gooseneck kettle. I own a kettle now, a good one, but I do not want to take it traveling lest it get broken. Various "flow directors" are known and I first heard about it from coffee pundits, and I've also seen wire products aimed at campers. But you don't actually need a product, you need a piece of metal that sticks out. I've yet to decide on the ideal shape of such a protrusion, but a curved point is definitely better than a squared one. More of a flow, less droplets. It's still not a good flow compared to a gooseneck, but it's much better than pouring straight from a fat kettle spout or a measuring cup lip. Those have way too much force to them.
Another good improvisation when doing camping or picnic table type stuff, is using a square-sided ceramic cup to scoop your water from a pan. With a rounded cup you can't do it very well, it scoops very little. With a square-sided cup you can get it lower and scoop much more water at once. This can spare you needing any kind of dedicated kettle, as you can just boil water with any pot or pan that you already have for some reason. A square-sided cup also lets you pour water out of one of the corners, although you'll also want a silverware handle. Squared cups are common for decanting in various tea making traditions, which is how I became aware of the possibility. I got my squared cup from a Goodwill store for $1, but I've noticed you can get them at dollar stores for not much more than that.
If you've come up with any methods that work when you don't have your regular "more costly" equipment handy, please chime in.
I really like this approach. It reminds people that good coffee is more about technique than expensive gear.
One improvised method I’ve found useful is preheating the brewer and mug with the same hot water I’m already boiling, so I don’t need extra equipment to maintain temperature. I’ve also used an ordinary kitchen scale and a timer on my phone instead of buying dedicated coffee gadgets.
The silverware handle idea is especially interesting. It’s a clever way to reduce the force of the pour without carrying a gooseneck kettle. It probably won’t match the precision of a proper kettle, but for travel or camping it’s a smart workaround. Posts like this are valuable because they show that excellent pourover coffee doesn’t have to be an expensive hobby.
Yeah after discussion of my last brewing with City Girl coffee, it's likely the beans were 4 months old. Although surprisingly decent, brewing problems were far more likely to be from the age of the beans, than any of the improvised cheapskate fork techniques used. I'll make it a point to use the forks the next time I do some "known good" coffee.
