BongoJavaRoastingCo
- Oct 10, 2013
- 2
- 0
We have a 1957 Probat UO22. The arms of the cooling tray are very wobbly and they feel like a wheel with a broken bearing. It is causing the arms to move unevenly across the cooling tray surface. We have tried to disassemble the arm from the tray but we cannot tell how in the world it is connected. This is the roaster we have been using for over a decade and have managed to maintain it very well, however, we have never had this issue before so have never taken apart the cooling tray. The arms are attached to the central hub via bolts on the underside of the hub, but it is the hub itself that is wobbling around. On the underside of of the cooling tray, all the metal gearing is in tip top shape. So I am assuming the problem lies within the hub itself and/or it's attachment point to the spinning gear. But how oh how do I remove the hub from the gear piece under the cooling tray? Can anybody help?
Chris
Bongo Java Roasting Co.
Chris
