Problem with Milk frother on a Neff 7760N Integrated Domestic Coffee machine
Jimbo_lad
I have a 4 yr old machine that has become problematic at frothing milk. It does one cup then won't froth any more milk for a while. I've cleaned he frother and applied new silicone but still doesn't work every time.
Advice would be welcomed. Would new seals help; or a new frother?
This is super automatic espresso machine. Pretty difficult to fix.
I need more info to give you any type of advise.
What do you mean it won't froth.
You are not getting steam? Are you getting water?
If you can describe what is happening, we might be able to diagnose your problem.
This could be electric problem to boiler problem or seal.
Thanks for your comment CoffeeJunky.
Steam and water are fine. The issue is no milk being sucked up into frother, hence no milk froth. This has been an intermittent fault for a while. Actually its OK at the moment after I cleaned and put grease on the various rubber seals. So I suspect ageing seals is the problem.
