Roasting and packaging equipment
ThruMart
Custom 2019 28 foot tandem axle gooseneck trailer built with 1" foam board insulation, industrial interlocking FRP like is used in car wash and butcher shops, a rubberized coin floor, 50amp 110/220 service with interior electrical outlets and counter tops and LED lighting fixtures. For powering away from shore there is an electric start 12,000 watt 110/220v gas/propane generator with a 25 foot cable with RV and twist lock as well and 15 amp dogbone as well so you can plug into a regular outlet.
Sonofresco 2200 fluidbed roaster with Sonofresco overhead hood that vents to the outside of the trailer. Mazzer and Mill grinders, RoastRite agtron measurement tool. Packagers are a 10" pillow pack and 10" 3 side seal packaging machines. These make the brew bags and frac packs commonly used in restaurants and businesses. There is also 4 rolls of foil that go with the packagers or roughly 24,000 frac pack and 4,000 brew bags. Includes a 4 up single serve cup sealer for creating one cup brew samples for a modified cupping experience. Bunn fully automatic 7.5 gallon per hour direct brewer 110v/220v, gourmet filter holder and 5 push top airpots. Installed is a 110v 40psi 1 gal per minute fresh water pump and easy change 5 gallon water bottles for the brewer as well as hot water for samples at tasting events. Automatic Canister sealer for 401 can 120mm-170mm - this is a common size coffee can. Canopy fittings and framing for 10x30 sampling/serving area - similar to racing trailers where tent awning uses the trailer. 10ft x 20ft white popup with sides and windows.
Many more items to list and are selling complete. Trailer can pull behind an F150 short box and with the tapered front neck you will get almost 90 degree turning.
PM for more pictures and info.
Cheers
RM
