junkdigger
- Mar 6, 2008
- 4
- 0
A friend of mine is having a steam problem with an M2 machine. The problem is no steam through the wand, when you press the button for steam. Everything else seems to work OK. The thermocouple is out in the wand, so they have been doing it manually, by pressing the button for steam, then pressing it to stop. They can't afford the $ 600.00 for a new wand. Can anyone help me out in troubleshooting this problem? First thing I plan on looking at is the switch, and I assume there is a steam valve controlled by the switch. Is there any other component I need to check? Is there a common problem item when steam is not getting to the wand?
This forum has helped me twice before with this machine, and I thank you.
Michael
Michael
