This time I put a small amount of water in the bottoms of the mugs and nuked them both in the microwave for 1 minute. I wanted to make sure the mugs were warm, so that I wouldn't be worrying about that and make another mistake. One of the mugs, only was warm. The other was hot and the handle burned my index finger slightly. That was probably my brewing mug from before. I decided to make the hotter mug my filter / drinking mug, to give it a chance to cool down.
I nuked 16 fl. oz. of cold filtered water in the microwave for 4 minutes. Meanwhile I ground 3 tblsp of beans at 80 clicks. I dried the bottom of the brewing mug so that the start of the brewing would be consistently timed. I put the grounds in there. Checking the water temperature, it was only 65*C, so I just used it. I poured 12 fl. oz. into the brewing mug, covered it with the glass lid, and set a timer for 30 minutes. I need to double check whether the mugs hold very different amounts. I poured 4 fl. oz. into the filter to rinse it, then immediately dumped the water, to prevent the previous mistake.
Most of the grounds dumped into the filter. It's not easy to pour from a mug, and one has to do it with a bit of authority.
The brewing worked, the result is recognizably coffee, but the taste is "eh". Kinda off, like old coffee. I drank half the cup and tossed the rest.
Could be the dying coffee beans. Could be standing around lukewarm for a half hour, does it decompose something? Could brewing in a ceramic mug have anythng to do with it? That's a variable I'd like to eliminate. Most likely it is what it is though, and there are no heroics that will save these beans. Short of 8 hour cold brewing them.
I'd say it's proof of concept. Would like to try with some "known good" beans.
Maybe 20 minutes is better than 30 minutes? But 15 minutes at slightly higher temperature, was quite watery.
