features of plastic coffee bags
wengerwang
Barrier and moisture-proof. With aluminum foil, our bags ensure that freshly roasted coffee is protected from UV light, oxygen and moisture.
Reinforced structure of quad-seal style helps hold the bag shape better and be stronger.
standup bags with a tear-notch for easy opening, while ones with built-in ziplocks allow customers to re-close the bag after each use.
Allows for easy label on the back panels or valve application.
Coffee bag features:
1. Material structure: PET/AL/PE, the inner layer is food grade.
2. Size&Thickness: According to customer's requirements.
3. Printing(Color): Up to 10 colors with gravure printing.
Packaging
1. 100PCS turns with a soft rope tied and packed into a carton.
2. Carton size: 380mm*380mm*400mm or as per your requirment.
Service
We can also provide OEM service, only need the requirment of material, size, picture or samples, we will manufacture the perfect goods in a short time.
Our Core competencies:
1. Equipped with one set of imported computer-controlled 10-Color printing machine, two sets of imported computer-controlled 8-Color printing machine with a max width of 1.3m and a speed of 120m per minute.
2. Three sets of high-speed dry laminator and also heat cut machines, cold cut machines.
3. More than 30 sets of package-making machines
Cleantech Events
If you have a lot of different flavors and can't afford the gravure cylinders, another option is to purchase generic bags that can be used for all flavors. then you can use a custom label applied to the bag. You can avoid the cost of the plates used for other print methods.
