Mr Shave
- Jan 24, 2011
- 241
- 3
Hello,
Big Dawg generator is down still. Going to be doing an event in the morning and it dawned on me I should see if it can handle the load.
Does the first 2 digits of the Fetco serial number translate to the configuration number?
http://www.fetco.com/06_SPEC_SHEETS/CBS-2041e.pdf
There are several different configurations and I'm not 100% sure what I got
I noticed that all the config codes are the same, except for the last 2 digits. So if my serial number starts with 45, do I have that config?
Basically going to just be running brewer and 1 light on one of those 2kw Honda generators. It might be tight... I figure it will only be full load for the brew cycle which isn't that bad right???
Thanks everyone
Thanks everyone
