gaggia adjust OPV?
caronalexis
hi
Mod my gaggia espresso with preheat tube, pressure gauge and ... but adjust opv with my pressure gauge is ok? or require portafilter gauge?
thank
sorry have video but not have permission!!!
I would want adjustability as not all coffees are gonna be at their best around the 9 bar range. Commercially I ran my Aurelia around 8-8.25 bars of pressure for the coffee I used most of the time. People get hung up on the "it has to be 9 bars of pressure, 200 degrees, for 30 seconds" blah blah blah... What it HAS to be is good to YOU, which is all that matters.
Depending on where your pressure gauge is tapped in you should be able to insert a blind basket into the portafilter, operate the machine as you would doing a backflush and adjust pressure that way. Just don't get too caught up in this as you could end up chasing your tail trying to get it dialed in just right. Keep in mind that coffee freshness, grind, humidity, dose, tamp all affect flow rate, so adjust one thing at a time while keeping other variables as consistently as possible.
adjust opv
Thank for reply
Test, test and retest and 8 bar is pretty good for me!!! have joe flex tamper calibrate to 30 lbs and good grinder for consistently!! :)
Sorry I thought you were talking about your safety valve. OPV and PRV are usually reference points for the Safety valve and not the pump.
