Gaggia MM Burr Grinder- 7001 Instruction manual???
rondubbs
i just bought this grinder used, but it didn''t come with any instructions. i use a stovetop bialetti espresso pot and do not know what grind level to put this grinder on. can anyone help?
thanks
Does it have numbers to go by? Usually the lower the number the finer the grind.
GAGGIA MM GRINDER MANUAL
Click here for Instruction Manual:
http://lib.store.yahoo.net/lib/gaggia/mm.pdf
Grasp the upper container and turn it to the extreme right. This
positions corresponds to “very fine”. Turning the container to the left will result in a coarser grind.
Start with a position somewhere in the middle and see how that works for you.
