Help with pourover issues. Constantly needing to extract more
bradweber1982
everyone
I have tried so many different things but can't seem to fix my issue. *I am consistently in the lower left of the barista hustle coffee compass. *Always getting a weak, quick finish, tea like cup of coffee. *Here is my specs. *Any help is appreciated. *Thanks!!
Handground grinder. *Using setting 2.5 (started with 3.5 and keep going finer)
Beehouse dripper with #4 filter
Using 32grams of coffee for 505grams of water
Using 25-28 grams of coffee for 405grams of water
Water temp is good, boiling it then sitting for 15-20 seconds
Using 40-50gram pulses of water every 5-6 seconds until I hit my water weight
Thanks again!!
Sent from my SM-G955U using Tapatalk
How long does entire brew cycle take?
I think you need to pour slower. Longer contact time with water.
I like 40-50 gram slow(er) pours...see how long it takes to make it into the cup, entire process should be close to 4 minutes (not including the initial wetting)... a bit more at that volume.
So, wet the coffee with 30 grams... let it rest about 30 seconds and saturate.. then start your first pour after that, don't rush. If anything, you need to grind coarser and have more control over your water.
