i have water in the filter basket after use
htc8p
7
is it normal to get some water in the filter basket after use? isnt there not supposed to be any water in the filter basket after use? but i already put quite a lot of coffee grounds and tamped down firmly...i hope you can help me out. thanks!
shadow745
Well-known member
Aug 15, 2005
1,757
53
Central North Carolina
Assuming you're talking about after the shot is pulled, it could also be the fact that your machine has no 3-way solenoid to pull the excess brew pressure off the puck after extraction. Therefore you will have a somewhat soupy puck. Later!
manual_drip_brewer
7
New England
Your grind is too fine
The paper filters may clog up if the grind is too fine. Also, some beans may have cocao or spices on the beans, when you grind them up the cocoa will gum up the filter. :cry:
