Hi Guys,
I have Jura S95 on my table, working very well. Only the problem i have with this machine is very light crema. Also i have to use a setting of very high coffee amount to have a good taste. Playing with grinder doesn't help so much as well, it improved but only a little bit. The waste coffee table is very wet ( comparing to krups 8025 i have on my table )
After reading this forum, i already replaced all the o-rings on brewing, but it doesn't helps a lot. I did a small test with extraction time - my 40ml espresso is around 12 seconds. It's too short extraction.
I'm thinking about to change membrane regulator as i have a feeling pressure bar is too high. Do you have any similar experience on any advice what else instead of brewing might be damaged ?
Thank you.
Thank you.
