Hi guys Bear with me, I’m a noob here. I researched and can’t find my answer.
My K50 pours only 1/2 what it should on each cycle, it also pours water back into the water reservoir.
Here is what I have done so far.
1. Used paper clip on each needle.
2. Ran Vinegar.
3. Pulled top off the keurig and cleaned the check valve. Ran a cycle with out check valve and still had the same problems.
4. Pulled the bottom off and cleaned the filter for the water tank inlet. With out change.
Does anyone else know what it might be??? Any help would be great! Thanks in advance.
2. Ran Vinegar.
