I have a 4-month old DeLonghi Magnifica EAM3400. I''ve been using it mostly to make my home version of Starbucks''s Caramel Macchiatto. With the occasional shot of expresso once in a while, the machine is pretty much used for my caramel macchiatto.
We had some visitors over and I realized that I can''t make a straight drip coffee with this unit. It can make an americano, but the lightest setting is still too bitter to my guests, and we ended up adding water, microwaving, and fiddling with different amounts of creamer/sugar -- not the least entertaining.
Can someone please suggest a drip machine for me? I prefer to start with the beans I already have, have the machine grind them, and then make the coffee. I''m hoping to avoid a separate grinder for the beans.
Would it also be a good idea to use the beans I have? I am currently using the espresso blend from Starbucks. If I make drip, should I use the house blend instead?
Thank you.
Thank you.
