Hello,
I have a Breville 900XL Dual boiler espresso machine and a Krug grinding machine. I am successful at making single shot espresso and hitting the 8 bar pressure mark using the single shot single walled portafilter cup.
My challenge is when trying to make a double shot espresso using the single walled double shot portafilter cup. No matter how I try (changing the grind, tamping pressure, tamping depth) I can never reach more than 4-5 bar.
I have to revert using the double walled double shot portafilter cup to get to the ideal extraction pressure (8 bars). I find using the double walled double shot portafilter cup makes the espresso too bitter and off tasting.
Would you have explanations why I am not hitting the right pressure using the single walled double shot portafilter cup and how I should proceed to successfully use the single walled double shot portafilter?
Thanks!
Thanks!
