Packed with new features and capabilities, which will drastically improve the way you prepare your favorite coffee, Nanopressois one of the best and most versatile espresso machines. A truly unique addition to your coffee toolkit! Built around a newly patented pumping system, the Nanopresso is capable of reaching, with the help of your hands, a maximum of 18 bars (261 PSI) of pressure for unparalleled coffee extractions qualities. The Nanopresso works best with finely ground coffee that is tamped hard. It is delightfully easy to operate and simple to use. The Nanopresso requires 15% less force to pump compared to previous models (1st generation Minipresso). With Nanopresso, the power is in the machine, not in your hands. After each shot, Nanopresso maintenance takes only a few seconds. When necessary, the components of the portafilter are easily separated for deep cleaning.
NOTICE: Nanopresso does not heat up water
The Barista Kit is a full set of accessories packed in a small container. It expands the Nanopresso capabilities by allowing you to prepare double espresso (16 grams of ground coffee) up to 120ml. Thanks to its high-pressure extraction of 18 bar, Nanopresso takes full advantage of the larger filter basket and surpasses the extraction quality of most home espresso machines. Coffee lovers will be pleased to enjoy unbelievably rich espresso. The double espresso basket is a unique feature that can not be found in any other portable espresso machine. The Barista Kit comes with one additional 8g basket, two 16g baskets, a tamper, a larger water tank, and a bigger cup.
NET DIMENSIONS
2.44" x 2.8" x 6.14"
62 x 71 x 156 mm
NET WEIGHT
11.9 oz
336 g
WATER CAPACITY
80 ml
BASKET SIZE
Ø39 mm
GROUND CAPACITY
8 g (16 g with add-on)
EASY CREMA
DOUBLE ESPRESSO
(with add-on)
PRESSURIZED PORTAFILTER
COMPATIBLE NS CAPSULES
(with add-on)
COMPATIBLE DG CAPSULES
(with add-on)
INTEGRATED CUP
SPECIAL COLORED EDITION
MAX. PRESSURE
18 bar
RECOMMENDED GRINDING
EXTRA-FINE GRIND
BPA-FREE PLASTIC
MATERIALS
PA66, PA6T, PP, stainless steel, silicone...
WARRANTY
1 year
PACKAGE INCLUDES
Nanopresso, built-in espresso cup, filter basket, scoop, brush, multi-language instruction book, warranty card, and two stickers.
NET DIMENSIONS
62 x 71 x 156 mm
NET WEIGHT
11.9 oz
336 g
WATER CAPACITY
80 ml
BASKET SIZE
Ø39 mm
GROUND CAPACITY
EASY CREMA
DOUBLE ESPRESSO
(with add-on)
(with add-on)
(with add-on)
INTEGRATED CUP
MAX. PRESSURE
18 bar
EXTRA-FINE GRIND
BPA-FREE PLASTIC
MATERIALS
WARRANTY
1 year
PACKAGE INCLUDES
