Hi,
I got a Saeco Aroma around Christmas time and it's been a fun learning experience. The machine has run well so far and has been a great starter machine to see if I enjoy doing this, and I do. One slight issue has cropped up since it was new, however. The mahine has gotten a bit messier to use since new. Now, when I remove the portafilter, there is some residual pressure left that causes the espresso in the portafilter to work up and around the top of the portafilter, into the portafilter socket and down the sides of the portafilter. It didn't seem to do that when new. I have descaled the machine according to the Saeco instructions and have generally kept it clean. There is one thing that I did notice about it. After time, the holes in the portafilter basket seemed restricted, so I soaked it in some lemon juice and water, which cleaned the holes back to normal and reduced some of the mess. I have seen some alternate cleaning videos which show to run some descaling solution in the portafilter, which off of the top of my head, is not how Saeco writes up the descaling, so I haven't tried that method. I have had the portafilter apart. I didn't see any obvious blockage. It was generally clean. I wiped up some pieces and put it back together. I'm hoping that when I do my next descaling in a day or two, that it clears this up. I'll try the alternate method which runs the cleaner through the portafilter. Has anyone else had this problem? If so, have you solved it? Is there any part up in the portafilter socket that helps bleed off pressure and should be cleaned, or is that all controled by the portafilter?
Danny
Danny
