amorbavian
- Sep 22, 2011
- 2
- 0
Hey guys
Have been reading from the sidelines for a while and the reading led me to invest in a Silvia.
Just got it, installed it etc. and now I have my first problem.
Basically, it is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop it. I was able to turn the handle in the beginning. The only thing I did with the machine is to follow start up instructions: Open steam tap, press main switch and coffee switch at the same time. Close the steam tap when water starts running. Repeat a few times.
Then all of a sudden my problem started...
I guess and hope that some of you know what I am trying to explain and can help...
Thanks in advance...
EDIT: When I switch the main switch on, the steam wand starts pouring out water...then it turns to steam..it stops after some minutes and half a litre of water..then I tried to make an espresso..but again runs water through the steam wand...the coffee puck barely got wet..no coffee ran through the filter..WTF?
