Designs for improving current coffee brewing methods: (click on the pictures to make them bigger!)
Mechanical advantage press -
Get the delicious brew of an Aeropress but with the ease of a lever system that adds a mechanical advantage for easy pressing. Additionally, the sleek design will add an aesthetic appeal to any kitchen countertop.
(click to enlarge)
Vertical Grinder -
With this product you get the grind you want without the noise of a traditional electric grinder. In addition, with an opening at the bottom of the grinder, simply place the grinder above your filter or french press and let your grinds fall gracefully in.
(click to enlarge)
Roller Grinder -
By simply rolling this grinder on a countertop you can easily and quietly get the grind you want. Then quickly remove the end and pour into your desired coffee brewer.
(click to enlarge)
Hourglass Pour-over -
This product minimizes the attention time usually required for a traditional pour over cup of coffee. Instead of the iterated process of pouring water over the grounds, waiting, and then pouring again, this product allows you to let gravity do the work for you. Simply fill one side with the desired amount of water, place grounds within the filter on the other side, set water side on the hot plate, wait for it to come to a boil, and then easily flip the assembly and let the water pour over the grounds via gravity.
(click to enlarge)
Let us know what you think! Pleas take this short (7 questions) survey at the link below!
https://www.surveymonkey.com/r/PHDVBW2
For more information just reply to this thread with your question.
Thanks!
(click to enlarge)
Vertical Grinder -
(click to enlarge)
Roller Grinder -
(click to enlarge)
(click to enlarge)
Thanks!
