Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
That may be a significant part of your issue..... when you use RO it takes all of the minerals out of the water. When that occurs the coffee will taste "flat" or just lack depth of flavor. As far as temp goes, boil your water then pull it off the heat and let it sit about 1 minute, That will get you at least close enough.Oh, and, the water is well water, Reverse Osmosis. No chlorine.
