Hi all,
I was recommended to make an inquiry on this forum about the CS2 from Starbucks.
We've been called in to service this machine in a remote mountain location... with barely any training on it so I'm hoping to get some help.
The machine powers on and seems to function okay except that the external pump will not work.
When the machine is powered on and prompted to do the rinse cycle, the solenoid engages and lets water flow from the spout. However the pump does not cycle on. When testing the pump using the output test, it also does nothing.
I have removed the plug from the pump to check the voltage and I'm getting about 40V between the two hot lines.
Seems like it might be an electrical/wire issue... but nobody has messed with the wiring and I don't see any loose or cut wires.
Any ideas?
Any ideas?
