paypalboutique
- Dec 21, 2013
- 57
- 0
I have the newer doserless model where you can adjust your hopper's zero setting. You are suppose to tighten the burrs until they touch then lossen just enough so the motor spins by hand and that is zero setting.
Some people on other forums say they like 33-35 for french press and 25 for more bitter. Whether I brew with an aeropress, drip machine, or a 4 min extraction for pour over, I have to set it at 50-55. The numbers only go from 0-40 on the sticker. If I go lower than 35, it's too bitter. Setting 30 takes about 45 seconds for a double shot of espresso at 50 lbs tamper. Does anyone have a chart for the Rancilio Rocky grind settings for French press, Aeropress, pour-over, drip machine, espresso, turkish?
