Saeco Magic Delux Blinking Red Light
ibselec
I like to know if anybody has some information about Blinking Red Light on Magic Delux Saeco.
I have already Drain the water , and follwed the Booklet instruction. but I can not stop that from Blinking , that stops the machine from operating.
If you have any information or solution please let me know.
I have the Saeco Vienna Delux and the light blinks when there is not enough beans in the grinder, or when the knock box is loose or the water tray is loose. Play with every movable piece on the machine and the light should go off!
Good luck!
Kim
Blinking Red light (water) in Saeco Magic Deluxe
Hi There,
I happen to be facing the same problem you had (back in Oct 06) in regards to the blinking red light on your Saeco Magic Deluxe. I wonder if you found a solution or figured a way to fix it; I have already followed all of the instructions in the manual which have proven to be absolutely useless. The machine appears to be functional except that this blinking red light prevents it from brewing coffee or frothing milk. Can you help? reply at your convenience.
Regards,
B
Hi There,
Regards,
B
Hi friend, I know im like 19 years too late, but I was wondering if you ever figured it out? Mine is currently blinking but I can’t figure it out!
