Hello,
I have a Dacor CM24T in wall unit. The other day no water dispensed and I found the water supply tube to the brew unit that holds the coffee grounds was clogged. I cleaned the tube and and now water is coming through the spout. I now seem to have two other issues. One being that i am continuously seeing coffee grounds in the supply tube to the brew unit? Are they getting pushed back into the tube when the grounds are compressed?
issue two is after a cup is made and the grounds are removed from the brew unit, it seems to fill up with hot water. Could the solenoid be damaged when the water was block and now not shutting off completely?
Below is the image #144 where the water is filling after completion.
Thank you,
JR
Thank you,
JR
